asphalt paper can make smell, yes.
Radiant barrier under the slab is a waste of time and money. use real insulation, rigid foam only.
You are likely to be able to utilize heat stored in water far more easily and effectively in this case, and I find it unlikely that you've got a solar array that is so massive you need this much concrete to store its heat. I would skip this entire idea, insulate your first floor, and use a solar tank for DHW preheat and maybe to dump heat inside the house itself, not in a slab.
If you're going to condition the crawlspace, ok, but I wouldn't really think an "active" storage system in the concrete would be very effective for much. |
