cndnc
| 04 Dec 2008 12:47 PM |
Early 1970's house with original thermostats that were not working right. We replaced them with King Electric digital single and two pole thermostats. Often we find that the thermostat is not turning off when it reaches the the temperature we set it at. We talked to King and they replaced them. They didn't really have an answer for why this was happening. Put new ones in and the same thing keeps happening. Fortunately the thermostats have an off and on button we utilize just in case. Since the wires are placed in the plaster about a foot away from the wall on the ceiling this perhaps causes a cooler spot right above the thermostat, so the room can be much warmer but the wall is cooler and that might explain why it doesn't shut off when the room reaches the set temp. So does anyone know of a better thermostat that can regulate the room temperature with radiant ceiling heat? The plaster on the ceiling looks more like some sort of concrete and is just about as hard as concrete. We need to repair some cracks, what exactly is that concrete plaster called? Can we use that to fill in the cracks? Appreciate any feedback on this since so few know or understand this system. |
gregj
| 05 Dec 2008 03:52 PM |
Real plaster is very hard so what you have is probably normal plaster and anyone who does plaster work should be able to fix it. If you want to diy the repairs you should be able to find repair info for plaster firly easily in books or online.
Regarding your thermostat. Does it shut off at the same temp consistently or are you saying it sometimes shuts off and sometimes doesn't. If it's consistent then your best solution would be to adjust the setpoint lower until your desired room temp is achieved.
If it's inconsistent then maybe you need to replace them with something more reliable. |
cndnc
| 05 Dec 2008 06:21 PM |
Thanks for replying. It is inconsistant on occaision. When it is set at 68 degrees we will look at sometimes and it will read that it is 74 degrees in the room (it feels hot and that is why we check) and the red light is still on meaning it hasn't shut off raising the heat. So it knows it is above what we set it at. It has happened with the other ones in different rooms. It does fine most of the time but then it pulls that and I wonder how safe they are. I already had the manufacturer replace them but still this happens once in awhile. Do you know of another brand that works well/reliable and has one and two pole units? Also I really like being able to turn the heat off completely which these allow. These were about 60 dollars each. I recall it being kind of difficult to find replacements for the old original thermostats and King Electric was recommended and I think that was the same maker of the old ones. In the early 1980's I got one of the first fancy Honewell thermostats that you could program and that one worked fine. The professor of electrical engineering at local university who bought my little house as a rental was completely enthralled with that thermostat. So would Honeywell be a better way to go? I am open to suggestions. Thank you for letting me know about the plaster too. |
BillN
| 04 Jan 2009 09:59 AM |
Sometimes there is a setting on the tstat, inside, called cycle rate. Make sure this is at its slowest setting. An air system would need a fast setting, steam heat would need a slow setting. There probably is not a specific setting for ceiling radiant. There is another setting that might be called "heat anticipator" try screwing around with that. A digital stat might also have a "differential" setting. If you dont have these setting options available, you might have to buy a more expensive stat. Another option is to eliminate that stat altogether and run the system on reset control. |
cndnc
| 04 Jan 2009 04:19 PM |
Thanks for responding Bill. Well I tried to find such settings on the King Electric thermostat and had no luck.
Do you know of a brand that I should try?
What I still don't understand is if I set the temp at 68 degrees and then I check it and it says 73 degrees and the light is still on and the thermostat still hasn't shut off wouldn't that be something else? It doesn't do it all the time but frequently so we are worried about it being a hazard besides just making things uncomfortable. I can see where the ceiling heat when it reaches it's set temp will shut off and then it takes time for it to cool down and it could go up some right after it shuts off just due to the fact it is hot and dense and can take awhile to cool down. But clearly it knows it is 5 degrees over the set temp and it still doesn't turn off indicated by the light on the thermostat.
I thought maybe dust got down into it and I have blown on it and when it reads my warmer air it then clicks off. So it does have the ability to re-evaluate even if it is on some sort of slow cycle. I just think they weren't designed for this sort of application even though we were told by the company it would work.
We would be looking for a brand that has one and two pole options as well as the ability to completely turn the thermostat off. We like the digital display and being able to program the temperature, especially with the radiant heat since in the mornings it takes awhile to heat things up and to set it to do that before we wake up is really nice. |
cndnc
| 05 Jan 2009 01:19 PM |
Well I looked up the model of King Electic we have they are the ESP120 and ESp230. It says that they are electonically anticipated. It says that it has a 3 min. delay between cycles. It has a thermistor sensor. It doesn't appear that it can be adjusted and they do say they are designed for several types of applications and one being radiant. It is one of their Premium thermostats but I can say for a fact that the ones we have don't work effectively for radiant ceiling heat. Does anyone have any suggestions on what other brand and model to try? |
naia
| 25 Nov 2009 10:28 PM |
Turns out the thermostat can be attached to the wrong poles. If that is the case, the thermostat will turn off when it is set for a very high temperature ...and it will turn on as though it is set for "high" if it set for the lowest temperature.
It will look like you've turned it way down and it's not actually turning off. If that is the case, the wiring may be attached to the wrong poles.
Michas Mom
| 28 Jan 2011 07:31 PM |
I'm having the same problem with new Honeywell RLV310A thermostats for ceiling radiant electric heat. On Honeywells' web site these are listed for ceiling radiant heat. I've replaced 8 of these and the one in my living room has been replaced twice, so it's not the stat. I set it at 69 and when it does come on the digital shows it has droped to 61 and it just heats and heats. The thermometer across the room from it shows it is 78. I don't have a clue as to why I'm having this problem wiht only 1 stat. Any thoughts? |
BadgerBoilerMN
| 29 Jan 2011 08:28 AM |
All heating systems and the buildings they service have different response times. Make sure the anticipator settings are correct for radiant or more likely electric heat. |
Michas Mom
| 29 Jan 2011 10:55 AM |
There is no adjustment on these. These, accoring to Honeywell, are for radiant electric ceiling heat. You connect 2 wire on the back to the 2 wires in the wall, make sure the switch is for F and not Cel. These thermostats are on Honeywells web site. |
cndnc
| 14 Mar 2011 03:50 PM |
Well it has been awhile and I have learned a lot and want to help others to avoid the pitfalls I have had. I bought three king Electric ESP230s which are suppose to be 240v double pole, 22 amp, programmable thermostats. I went through 3 sets of these and even talked to Dean one of the owners. His excuse was that there was an algorythum problem with them. If you set the heat on 68 degrees it would just keep going and never stop the heat from rising way beyond that. They had them made in some place like China and stamped King Electric on them. But Dean said he tested them last batch before sending them to us. Now they don't work not matter what temp you set them at. They work fine in the beginning and then they just don't. These in my estimation are a fire hazard since they don't seem to shut off either. We have to turn off breaker when we catch them rising out of control. Even it you turn the off switch off with them. Well there are many who also had problem with these. I would highly recommend you steer away from these pricey defective units. I think like with baseball three times and your out with us. I am not sure who you would report this to but I think what they are doing is very questionable. One thing I learned was get yourself a clamp meter and test the radiant ceiling zones for how many amps each zone takes. You do this by taking off the thermostats to test the wires. You must be very very careful and find out how to use your clamp meter before attempting this. The 240v wires are dangerous. We found one zone was only 6-7 amps, another zone 16-17 amps and a third zone 19-20 amps. My King Electric thermostats are beginning to fail and even called Dean but he didn't return the call now. Even he wants this nightmare to go away. So here is what I have found and what I will buy next. No one makes a programmable line thermostat for 22 amps. You have to go manual. But many manuals have a wide range of differential as much as 3 degrees. With radiant ceiling heat that can be a big difference. If I had set it to 70 degrees it could swing upwards of 73 and that is hot for us. Finding a manual with the least amount of differential was important along with positive feed back from consumers since King Electric's should have worked but failed miserable time and time again. White Rodgers makes a manual with only 1 degree differential which is outstanding and couldn't find any others that could. It doesn't look great but you can get in white and another color. I wanted white the model number is 1A66W-641 the W in it is the white colored one. These I will place in the 16-17 amp zone and the 19-20 amp zone. You can find them online for around 29-36 dollars. For the 6-7 amp zone I will probably go with the Honeywell TL8230A1003 which is programmable and I found it online for about 47.00. I have spend literally days and even weeks on trying to find thermostats for this older ceiling radiant heat and made dozens of calls to manufacturers and suppliers for options. I guess you could do some sort of relay set up to lower the amps on the zones possibly but really not something we would want to attempt and to hire someone to do that is cost prohibitive on a 1970's system that only has so much life left in it. I hope this helps others who are dealing with these orphan heating systems. |
