Programable Thermostat
Last Post 21 Jan 2009 06:10 PM by Dana1. 1 Replies.
Block42User is Offline
18 Jan 2009 03:49 PM
I have a vacation home with a 6 zone wirsbo hydronic system in a 4 inch slab (insulated underneath).  I have an electric boiler and am utilizing a demand controller from the energy company which gives me relatively cheap electricity on off peak hours.  My theory is when the place is unoccupied to heat the slab on off hours for 3 cents per kwh and let it dissipate heat during the day and not run the boiler at the higher peak rate. I would like to change the current wirsbo thermostats and convert to programable.  I could use the demand controller to accomplish this but I let other people use the cabin and it is too difficult to explain the demand controller.  I am hoping they can figure out how to run a thermostat.  There is a heat pump I use for backup (I need AC a few weeks per year).  So I have 2 questions:
1.  Will this work in theory?
2.  How do I wire a set back thermostat to the current 2 wire system?
Thanks in advance.
Dana1User is Online
It sounds like you want to let it just coast on thermal mass during peak-rate hours when your not there, right?
In which case what you need isn't a setback thermostat, but rather a programmable timer switch wired in series with the Wiirsbo. Keep the standby temp high enough that the pipes won't freeze, but it should basically work. One COULD use a programmable thermostat as the timer, but it has more function than you need.
Membership Membership: Latest New User Latest: tadams New Today New Today: 6 New Yesterday New Yesterday: 14 User Count Overall: 17354
People Online People Online: Visitors Visitors: 547 Members Members: 53 Total Total: 600
