Posted By BadgerBoilerMN on 01/26/2009 10:03 AM
Good observations in general, But "I can't tell the difference....."
You would be the first.
Or maybe the second, depending on just how low the heat loss is.
Folks in super-tight, super-insulated houses (R40 wall, triple-pane windows, etc, etc.) would have to run radiant "hot spots" to have areas of floor that actually felt warm. IIRC the Riverdale Net Zero home project in Edmonton Alberta had a heat load sufficiently low that heat distribution was via "barely forced
tepid air" circulation via the HRV ducting. A full radiant floor there would only be a few degrees above ambient- very hard feel, providing very little (possibly negative) efficiency improvements. A radiant "hot spot" in each room might
feel nicer though.
Assuming this is standard ICF construction with a clear-wall value of R20-R30 and a R60-R70 roof you can still get the cushy warm radiant floor effect by selecting only areas to be warmed. But in an average lower-48 climate you may be also able to heat a structure like than more efficiently (& still comfortably) with a tepid-air hydronic coil in a low/variable speed HRV air handler, as in the Riverdale project house. Almost all standard hot air furnaces or hydronic boilers are likely to be overkill in the first place, if the building envelope is sufficiently well engineered & executed. I'd agree that redundant systems just adds to the expense, not the comfort- either go with zoned hydronic/radiant or hot/tepid air, not both.
There's a bunch of info online about the Riverdale project, but a technical summary lives here:
http://www.riverdalenetzero.ca/RiverdaleNetZeroProject-TechnicalProposal.pdf
and the (9mb- watch out!) presentation slide version lives here:
http://www.riverdalenetzero.ca/PRESENTATIONS/Riverdale_NetZero_energy_home_--_presentation.pdf
