If an R4 glass wall doesn't affect comfort I guess an R4 insulated wall would be comfy too... it's an improvement, but it's not the end of the story. depends on glass area, construction method, proximity to regular occupation patterns... I'm sure it can be nailed down to some guiding principles, but even then, it's basic training your building team needs to execute.
agreed pv/heatpump is the way to heat with solar... that's why we're doing it
it's not hard to do your kind of approach if that's what you do and you have a client happy with Ecobox design. it's hard if you are a regular architect or builder and you have a client with a view... I work with marc on projects occasionally that blow my ecobox characterization out the window and still hit very low heat loads, it can be done, but takes more than just R value to make it happen, it takes someone like Marc, a well defined building process that includes verification steps, builders that know how to execute to a high degree of detail, and architects that know how to design.
it's that or you build a simple ecobox. me, I like ecoboxes. built one for my shop. but then, I'm an energy wonk of sorts, and definitely in the "unconcerned with aesthetics" camp. My wife would not be pleased with my building design decisions...
again, I'm not saying radiant is always the way to go, that's in danger of becoming a straw man in this discussion, no one here has ever even tried to insinuate that. I AM saying distribution can be improved beyond single-point-source... i.e. more heads, ducts, or hydronics (radiant or otherwise)... in most homes, including an awful lot being built by pretty green people these days. the homes being built that are really suitable for single point heating... or monitor heaters before them... are fairly small, at least if a consistent comfort level is actually valued.
there are also people who will happily keep their money in the bank and deal with less comfort, and plenty who don't notice discomfort because they are used to it. they have monitors in their homes now and don't care that the bedrooms and bathrooms are 60 degrees. probably use less energy as a result too.
