Radiant tube spacing ICF home concrete slabs
Last Post 27 Oct 2012 02:09 PM by sailawayrb. 22 Replies.
MikeSolar
| 24 Oct 2012 09:49 PM |
I just saw this post for the first time and given that you want to use a GSHP, the best thing you can do with tubing is to keep it tight because that means a lower water temp and therefore a higher HP efficiency (or if you want to use solar, a greater solar resource). |
| www.BossSolar.com |
NRT.Rob
| 25 Oct 2012 09:20 AM |
if loads are low and floor coverings non existent or not resistive (tile) tighter on centers aren't much help. tubing is cheap though. don't skimp if you're guessing. |
-=Northeast Radiant Technology=- NRTradiant.com |
sailawayrb
| 27 Oct 2012 02:09 PM |
There are some good heat loss analysis, passive solar design (including roof overhang design), hydronic radiant floor heating design, and integrated heating system performance calculators at this website: http://www.borstengineeringconstruction.com/Calculators.html There are also calculators for water work projects (e.g., cross flow turbine, water wheels, hydraulic ram pumps, ditch/pipe flow rate capacity, etc.) |
TwoStepsBack |
2 |
4 |
26461 |
297 |
24 |
321 |
