Here is a link to some pictures of the boiler room -- there is also a picture of the closet on the other end of the house.
CLICK HERE I am in climate zone 4 (WI).
It appears to be a Weil-Mclain Gold GV boiler installed in late 1997, which I think is condensing?. All water valves in the room are fully opened. There are no floor sensors or outside sensor
I could not find a model number on the 120V pumps.
The control board is a ARGO ARM866DP. There are spots for 6 zones, 5 are being used. The first zone is labeled priority. When the water tank thermostat calls for hot water the light for the Priority zone lights and the boiler fires up. The remaining 4 zones are the 3 zones in the house and 1 in the garage. IF I turn up any of the thermostats in the house past current room temp it will kick on the designated zone light and the water heater will fire up.
When I inspected the house at the beginning of November the thermostat on the water storage tank was damaged and disconnected so the priority zone was never on and there was no domestic hot water unless we jumped the wires that get connected to the thermostat on the tank. I would notice the lights for the other 4 zones on and the house thermostats were set at 62 degrees (Actual room temp was getting about 70ish), gararge thermostat was disconnected so that zone would not run.
When I bought the house 2 weeks ago I immediately replaced the thermostat on the water storage tank -- since then the house has been very warm since the water storage tank calls for heat a lot, and the boiler seems to run a lot, despite all of zone lights (except priority zone) never coming on.
I realize I will likely need to get a radiant guy on-site to take a look, but I'm mostly interested in learning how this system is supposed to work since I'm going to be living here for awhile!
Let me know if there are other questions or more pictures that are needed to help me figure this thing out!
Thanks so much....
