Using free software on http://www.borstengineeringconstruction.com/Heat_Loss_Analysis_Calculator.html, I came up with the following btu/h. Because I live in one of those states where unlicensed hvac designers/installers run rampant, finding a pro with manual J experience was a daunting task when I put in my mod-con last year. Like most DIY's experiences on this board the installer's first advice was "you don't want to under size your boiler", local dudes simply used baseboard ft x 600btu/h to size boilers and these dudes were charging a pretty penny.
Given the situation and being an engineer who models/designs optimization for a living, I trust my data more than these local dudes. As engineers we all know any user software is only as good its operator. Going back to my original ask, would appreciated if anyone can share their experience(s) with radiator panels vs. baseboards in terms of comfort/efficiency Am sure there have been threads on this topic, but the search function didn't seem to return favorable results.
1st floor
6493 btu/h with R-3.22 windows/R34 walls
5622 btu/h with R-5 windows/R34 walls
7216 btu/h with R-3.22 windows/R14 walls
6345 btu/h with R-5 windows/R14 walls
basement
4020 btu/h with R-3.22 windows/R30 walls
3560 btu/h with R-5 windows/R30 walls
4817 btu/h with R-3.22 windows/R14 walls
4357 btu/h with R-5 windows/R14 walls
I suppose my next task would be to do a fuel cost analysis between a R14 vs. R34 wall to find the optimal trade off.
