Posted By 250ratc on 03 Mar 2014 05:40 PM
I appreciate the feedback thanks. I really like the idea of a minisplit system. I have no experience with them. I like the idea of its simplicity and ability to heat/cool 2 zones without ductwork. My main concern is how well will it work in my area with our cold winters? Any thoughts? I heard they have auxillary electric heaters in them to assist on those days (which there will be a lot of!)
Your climate is not nearly cold enough to be a problem for mini-splits designed for low temp operation. Your 99% outside design temp is probably no colder than about 0F, and your 99.7% temperature bin is probably still north of -10F (though it probably got colder than that for a few hours out of this year.)
The
Fujitsu Halcyon XLTH series has a rated output capacity at -15F, and will operate even at -30F putting out an unspecified amount of heat.
The Mitsubishi H2is are have rated outputs a -13F and keeps running at lower temps (I have second hand reports of heating at -22F outdoor temps). The standby go-to mini-splits in New England has been the popular Mitsubishi MSZ-FExxNA, but there is an updated
MSZ-FHxxNA series with efficiency specifications that are considerably better.
For a basement with an open floor plan it's likely that a single-head 3/4 ton is the right choice, and would likely come in under 3 grand as turn-key pro installation, under $2K for a mostly DIY with a couple hours of tech time for the final system pump-down/refrigerant charge/test. The AOU-9RLS2-H puts out about 15,000BTU/hr @ +5F and 9000 BTU/hr @ -15F.
The
MSZ-FE09NA puts out about 11,000BTU/hr @ +5F and about 8000 BTU/hr @ -13F. The newer -FH09 NA puts out comparable heat, but uses 15-20% less power.
Check out the
3rd party bench testing of a couple of 1-tons from a few years ago. They've all gotten better since.
Unlike most ducted air source heat pumps, mini-splits do not come with auxilliary strip heaters, though the cold-weather versions have small heaters to keep the compressor warm enough to start without damage when it's -10F out or whatever. Defrost cycles on some of them are executed automatically by running them in air conditioning mode at low speed for a few minutes when ice-up is sensed, but you have to pay close attention to actually observe a defrost cycle.
Best practice is to mount the outdoor unit where it won't be buried in a roof-avalanche or drifting snow. Bracket mounting it where it's protected by the overhanging rake of the roof, with the bottom above the historical snowpack depth saves you from ever having to dig it up after a big storm. Mounting it under the eaves works too, as long as the overhang is sufficient to fully protect from icicles & ice dams, and you allow for some additional snow depth. If you don't have sufficient roof overhangs it's worth building a shed roof or open dog-house with sufficient clearances on all sides so as not to restrict air flow, as that would affect both capacity and efficiency.
