Radiant Heating
dave111 about your install of tile and wood over radiant. I have a question
Last Post 05 Jun 2014 04:23 PM by
dave111
. 6 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
layth
30 May 2014 12:02 PM
I have completed my install of plywood rips and heat transfer plates and will finish placing the pex tubing today.You said earlier you used Ditra under you tile for uncoupling but did you use anything on top of the rips and plates first like 1/4" of dura rock or some other cement board or did you use thinset directly on top of the plates and rips? We will be using slate. Thanks, Tom
dave111
30 May 2014 08:21 PM
Howdy;
I used latex modified directly on top of the rips and plates, it will take a little more than you normally would expect as you are filling in the top of the tubes. Then the Ditra on top, I found a 2x4 works well to bed the Ditra and level it out. I did this way because the stackup height was almost identical to the engineered floor I used elsewhere. It also minimized the material between the tubes and the room, I'm getting about 15 Btu/sqft-hr out of it. I have also had no problems with it, although I did have my wife back butter all of the tiles as we set them.
layth
31 May 2014 11:23 AM
Thanks for the reply. I guess my concern is I used double wide plates and kept them fairly close together so that's a lot of metal to cover with thinset but maybe the vinyl modified stuff will do the trick. Tom
dave111
31 May 2014 03:23 PM
Are the centers of your plates supported on rips? If yes I would go ahead and place the thinset on it, the modified sticks to most things.
layth
31 May 2014 03:59 PM
Yes six inch rips on the sides and up the middle. I like the idea because I wouldn't have to screw down Dura Rock and worry about my tubing being punctured. Thanks again for your input. Thankfully the rest of the rooms will be engineered wood. Tom
FBBP
04 Jun 2014 11:00 AM
Are the plates compatible with cement products?
dave111
They are aluminum, however to quote a Reynolds study: "...aluminum is not affected beyond a slight surface attack by concrete...". They note that this attack is on the order of 1 mil, and that as long as the interface does not suffer repeated wetting and drying the effect is gone after 4 or 5 days. So if you are going to attach aluminum windows to a concrete wall outside it would be a bad idea, however indoors under tile not much of an issue. It should be noted that if you are worried you could roll a coat of paint down before you set the tile.
Radiant Heating
Membership:
Coconut Canadian
People Online:
