Radiant Heating
Cast iron pump & flanges with copper pipe?
Last Post 30 Oct 2014 09:13 AM by
sailawayrb
. 1 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
John7
21 Oct 2014 12:30 AM
Reasonably priced pumps are CI and their flanges too. Is galvanic corrosion with connection to copper piping a problem? I understand dielectric couplers often end up leaking... Would be closed system with oxygen barrier PEX if that makes any difference (doubt it with galvanic corrosion). Thanks John
sailawayrb
Don't mix metal component materials if you want to avoid galvanic corrosion. While oxygen barrier PEX won't do much to mitigate galvanic corrosion, it should always be used in hydronic systems to mitigate normal corrosion issues.
Radiant Heating
Membership:
hudson2000
People Online:
