I have a similar question in terms of heat load calculation: Assuming I want to have the same temperature throughout the house is it anything wrong to consider the house as one big room and taking into consideration only the roof, exterior walls, windows, doors and the slab/basement floor into account? Would it be wrong to ignore the interior partitions as in most of the cases they are not insulated anyway (they may have soundproofing, but the insulation would not be the same as the exterior walls anyway) ? Basically I consider the house as one entity to heat/cool as I want the same temperature throughout the entire house. Even if the heating/cooling is zoned, because of very low or nonexistent insulation on the interior partitions on the long term the temperature will be even in the entire house (maybe with the exceptions of the low insulated areas like windows and doors where there will be a difference of a few degrees but negligible) as the heat transfer is faster within the interior space. Note: I agree that, if for instance I have an uninsulated/unfinished basement then this would require a different approach. |
