Radiant Heating
In floor thermostat
Last Post 07 Apr 2015 09:17 AM by
NRT.Rob
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
sx700r
07 Feb 2015 01:55 PM
My in floor heating is cooling my house in winter. If my water storage tank temp is cooler than my house temp and my thermostat setting is calling for heat, it runs the pumps effectively cooling my home when I really need heat. My geothermal heat pump is on an off peak power connection, so power is not supplied to my heat pump all of the time. Anyone know of a thermostat that will not call for heat if the supply water temp is cooler than my current house temp? Rick
David_lee
07 Apr 2015 02:49 AM
There are variety of thermostat available in the market. There are various options when purchasing low-voltage thermostats. These are the cheapest and easiest to install. A consumer by hand adjusts the thermostat to the temperature he or she wants.
ChrisJ
07 Apr 2015 07:45 AM
Use a programmable thermostat that you can set back the temp during the heat pump off times.
Or power the tstat from the HP power. No power to the heat pump, no tstat to call for heat.
Chris
NRT.Rob
I think Chris is giving the easiest answer. If you want to do this with water temp though the easiest way to go is to set a "go/no go" temperature on the tank itself. Thermostat goes through an aquastat or to a "setpoint" control that will only pass the demand through if the tank is over a set temperature (say, 80 degrees or more).
Radiant Heating
Membership:
HotnCold
People Online:
