I was once enamored with engineered flooring but the quality, like any man-made product, varies with the man. Pads of any kind should be avoided since they all resist heat transfer. When a pad is used, either under hardwood or carpet, the radiant designer must be made away so the system can be modeled with the R-value of the pad accounted for. First make sure, talking directly to the factory, that the engineered flooring you have chosen is indeed compatible with radiant floor heating at the design temperatures you are using (another question for your designer). We prefer real 1/4 sawn flooring and a paper pad if you must. I used 3/4" pre-finished oak over 100 year old 3/4 T&G, no pad or paper. One creaky spot missed in the sub-floor by the prep guy, me. Lose the pad and tell them to install it carefully or choose a more compatible flooring and perhaps a new installer. |
