Posted By pfoley on 11 Aug 2015 09:21 AM
Does glueing 3/4" solid hardwood (quartersawn rustic grade white oak) to a 3/4" ply subfloor over radiant help or cause problems with wood flooring expansion/contraction and heat transfer ?
I have a 5/8 subfloor with sleepers and attached PEX and then 1-1/2" of poured concrete on top. On top of this there is another 3/4" ply subfloor. This floor structure has had about 8 months to dry out.
I would now like to install the 3/4" solid hardwood on top of the 3/4 ply. In addition to nailing the flooring to the 3/4 subfloor, could I ask for advice on benefits or pitfalls for additionally gluing to the subfloor. And if a good option, any recommendations on type of glue?
I think instead of gluing one more layer it is better to add a rug or a
carpet which will not only be affordable but also protect the floor underneath it.
