Posted By rodney757 on 20 Jul 2016 08:55 PM
sorry for the long winded post, all the formatting disappeared.
Yea depending on your browser, the formatting may need to be done in HTML code... If you click the "quote" option on this post, you will see the code string to perform a line break. Can't type it as the forum engine will simply act on it and add a break:)
That's an unusual floor alright, since the gravel is setting on/surrounded by earth, I would think it would perform more like a slab on grade than anything else. Because of this perimeter insulation around the outside of the stem wall would probably be in order to further isolate the under floor area from the outside earth surface
The maximum tube length has a bit to do with how much fluid you need to push thru it to deliver the required heat per hour. The faster you need to flow water to deliver heat, the greater the friction(and noise) per foot of tube, thus the need to reduce individual tube length/make more circuits...
The typical electrical water heater element is 4.5KW or good for about 15KBTU/HR The rub here is that they may not be a good choice to run at that full output for extended periods(100% duty cycle)as the elements and controls are designed for cyclic operation. A small purpose built electric boiler might be a better choice for that much sustained heat output.
24' diameter is about 425 Square Feet? Is this a permitted structure? You may have an issue attempting to use a domestic hot water heater in a space heating only application...
Yurt's are interesting, but not a lot of insulation. I don't think I would build one, other than a tiny one as a cabin or day use shelter, and then only because it would probably assemble a lot like a tent. I personally would want a lot more wall/ceiling insulation in something I was going to spend any length of time in. IF you re-run your calculations with say R20 walls and ceiling, I think you will find the energy usage numbers a lot more appealing... I am also not sure how well sealed the yurt typically is. In a leaky structure air infiltration can quickly dominate the heating equation. I am pretty sure I could make a round yurt looking structure that is significantly more energy efficient...
This of course is just my personal opinion and preference, but when it comes to energy usage, I believe less is always better than more... It surely isn't going to get any less expensive to procure energy...
Good Luck with your project.
