Geothermal well cost
Last Post 28 May 2009 09:23 AM by Bergy. 47 Replies.
Page 1 of 3123 > >>
PatrickTUser is Offline
17 Jun 2007 10:28 PM
What does it cost to have a geo wells drilled? I have seen several web sites that drill smaller dia holes than the typical water well. The drilling equipment is much smaller as well. Top layer is sand stone, but could be limestone once deeper.
Patrick T
megatekUser is Offline
29 Jul 2007 11:13 AM
That typically varies by geographical location.  Not only due to rock formation, but also travel expense for the driller, and the amount of local awareness.
Typically, a "midwest-borehole" will cost between $1100 and $1600 per ton.  Some areas are in ecxess of $6,000 (some eastern US areas)
John Herbert
Sales Engineer
www.hydroheat.com
ArdoseUser is Offline
03 Aug 2007 09:15 PM
I had one six inch well drilled 150 feet deep. I used a submersible pump to provide water to the heat pump and for household use. The heat pump discharged into a pond. The well was bored by an amazing drilling rig that did it in just a couple of hours. In Ohio, it cost six thousand dollars including the pump and pressure tank.
geodeanUser is Offline
04 Aug 2007 08:22 PM
in Utah geothermal wells cost  $1500 to $3000 each  depending on location and quantity of wells to be drilled
www.PalaceGeothermal.com
Why settle for 90% when you can have 400%
We heat and cool with dirt!
visit- http://welserver.com/WEL0114/- to see my system
08 Aug 2007 09:46 PM
great topic !
John Herbert
Sales Engineer
www.hydroheat.com
hedgehogUser is Offline
13 Sep 2007 10:34 PM
here in saskatchewan canada the goin rate for verticle loops is $4.5 to $5 a foot for holes 100 to 200 feet, 3/4 hdpe pipe, fused and pressure tested into yer house. my driller is here and supposed to be drilling mine in the next few days. thier rig is a modified siesmec survey rig.
Dave-iin-MDUser is Offline
30 Dec 2008 10:58 AM
I have talked to three companies around the Washington DC area.  They want $9000, $12,000 and $13000 for 600-640' (two wells) of drilling for a 4-ton system.  That price includes installing pipe all the way into the house (a little trenching and core drilling into the basement).
30 Dec 2008 12:06 PM
$10 per foot here in North Florida
Curt Kinder
Absent data, you have only an opinion.
www.hoviscustombuilders.com
BrockUser is Offline
30 Dec 2008 03:38 PM
At our last home we paid $10/foot just for the drilling part, it was just over $2000 to get them on site, prep and cleanup.
Green Bay, WI. - 4 ton horizontal, 16k gallon indoor pool, 1.8kw solar PV setup, 3400 sq ft
danielzUser is Offline
31 Dec 2008 01:25 AM
Southeast Pa - 15.50/ft complete (excavation, drilling, piping, grout) to house.
Extras were:
         Time and Materials inside house to units and insulation of the pipes.
         Propylene Glycol
         Fill/Flush/Pressurize
2000 ft in drilled wells and about 50ft inside house for three separate loop sets (6 lines in-out) ran approx $30K.
HabeedUser is Offline
01 Jan 2009 08:59 PM
Does that mean you could DIY a geothermal system? If the well was already dug, and pressure tested...
arkieoscarUser is Offline
01 Jan 2009 09:10 PM
There's a lot of open loop systems around here. If the water quality is good and you have the capacity to both pump it out and someplace for it to go, it's very efficient. Several companies sell package units that you can hook up to your duct work, your water source and disposal and electric service and be in business. You still have to do your homework to select the right size, model and make sure that you understand what is needed before you buy any equipment.
01 Jan 2009 09:17 PM
Don't forget to factor in well pump power for open loop - it can be quite significant.
Curt Kinder
waterpirateUser is Offline
05 Jan 2009 06:30 PM
Hi all,
I see some familiar handles from the other board.
On the Delmarva Penninsula we charge 1600.00 per loop, or ton of load. Typically 3/4" loopsX200'.
This price includes: install the loops, dirt work, manifolding, methanol, pump pack, hook up to units, purge flush pressurize system. For every four loops of load you are eligible for another seperate pump pack if you desire.
Eric
Eric Sackett
WeberWellDrilling.com
05 Jan 2009 09:32 PM
Hi Eric,
Welcome aboard. You are providing a lot of product and service at a very reasonable rate. Way to go.
06 Jan 2009 06:20 AM
Hi Dewayne,
Practice makes perfect, and efficency makes profit.
Eric
Eric Sackett
arkie6User is Online
06 Jan 2009 08:07 AM
Here in central Arkansas, I was quoted $5/ft to bore the holes and it takes ~200' of well per ton of capacity. This is just the cost for the well driller - pipe and labor to install it would be extra.
Accurate1User is Offline
15 Jan 2009 09:28 AM
Hello, I am the owner of a drilling and blasting company in Rhode Island. We have drilled five systems now. We are trying to get our cost lower and we price each job individually. It is better for us to have solid ledge on site as we use tophammer drill rigs. The advantage seems to be the speed. We average four 100 foot holes per day and have a pretty good record of six per day with twenty feet of overburden. The cost associated with drilling has many factors. The most expensive for us is the cost of the drill sleve set up. We also are limited to 110 feet in solid granite but we are involved only with the DX systems which require up to 100 feet. We also install the loop, grout, and provide the excavation. Check our web site at: www.accuratedrillingandblasting.com
16 Jan 2009 01:41 AM
We pay up to $3,000/ton (150' u-tube) in MI.
Joe
Just a Mechanic;
Geothermal; Savings Underfoot
rainierUser is Offline
23 Feb 2009 08:21 PM
is there a standard cost in core drilling? if there is, how much? this will be used to further study the characteristics of the geothermal site/reservoir. site is in the philippines.
Page 1 of 3123 > >>
Membership Membership: Latest New User Latest: Mary2quinn New Today New Today: 8 New Yesterday New Yesterday: 11 User Count Overall: 17342
People Online People Online: Visitors Visitors: 615 Members Members: 51 Total Total: 666
