hdpe vs. pex for horizontal ground loops
Last Post 13 Sep 2007 09:16 PM by geodean. 2 Replies.
Ring900User is Offline
12 Sep 2007 11:11 PM
I'm putting in six 500ft horizontal ground loops of 3/4" tubing for geothermal.  No joints will be in ground; all loops will run to manifold inside.  I know hdpe (astm 3408) is almost universally recommended, but haven't seen any technical reason why.  Ideas?  Also, if I use pex, is an oxygen barrier needed?  I don't see why and don't think hdpe has oxygen barrier.
- Ted
Gary W.User is Offline
13 Sep 2007 06:54 PM
Barrier tubing costs a bit more but it'll protect your system against corrosion. HDPE does not have a barrier. You can buy PEX tubing with or without an oxygen diffusion barrier. The thing that will determine weather or not to use barrier tubing is the use of ferrous components within your system. No iron allowed in systems without a barrier. I'd use PEX over HDPE because it's a smaller molecular structure and much more flexible.
Wallace Radiant Design
http://radiantfloors.googlepages.com
geodeanUser is Offline
HDPE is the standard. It comes with a 50 year warranty from the factory. I know of hundreds of geothermal systems using HDPE. I don't know of one using PEX.
www.PalaceGeothermal.com
Why settle for 90% when you can have 400%
We heat and cool with dirt!
visit- http://welserver.com/WEL0114/- to see my system
Membership Membership: Latest New User Latest: ecoSmart Solar Powered Building/Remodeling New Today New Today: 4 New Yesterday New Yesterday: 10 User Count Overall: 17379
People Online People Online: Visitors Visitors: 588 Members Members: 70 Total Total: 658
