dancour
engineer
pyropaul99
| 26 Mar 2009 02:39 PM |
Posted By engineer on 03/26/2009 1:31 PM Insulation on ductwork? Looks like it's in conditioned space and probably has internal (acoustic) insulation if it's anything like the ductwork I have. I don't get any problems with the ducts sweating in the cooling season. Paul.
geo fan
| 26 Mar 2009 03:00 PM |
I dont see the grip nail dimples
pyropaul99
| 26 Mar 2009 03:13 PM |
Posted By geo fan on 03/26/2009 3:00 PM I dont see the grip nail dimples
My ducts don't have any visible either - but there's definitely acoustic insulation on the inside. I'll see if I can dig out any photos if we don't hear anything from the OP. Paul.
dancour
| 26 Mar 2009 05:10 PM |
I appreciate your comments on this install.
Yes, it's in condtioned space and the ducts have acoustical inside for 10 feet each way (glued and pinned)
I'll try to add another pic of today's plumbing if I can figure out how to reduce the pic sizes. It took me long enough to get them down to 100kb. :-) |
dancour
engineer
| 26 Mar 2009 08:38 PM |
I figured the ductwork had inside insulation but it couldn't hurt to ask. |
Curt Kinder
Absent data, you have only an opinion.
www.hoviscustombuilders.com
dancour
| 27 Mar 2009 08:43 PM |
Never hurts to ask.
We can't figure out how to add air that is silent(to prevent a vaccum) on the out going water line .
Any ideas??? |
joe.ami
| 28 Mar 2009 08:14 PM |
Flow raters are noisier than vacuum break. Put both outside and noise is no problem. J |
Just a Mechanic; Geothermal; Savings Underfoot |
dancour
| 28 Mar 2009 09:30 PM |
That's a good idea about putting the air intake outside but the line exits under basement floor and continues 4' under for 100'.
I thought you might enjoy seeing the finished install by Jack's Heat Pumps.
Attachment: Jack's Heat Pumps - classic install 1c.jpg
heatoftheearth
| 29 Mar 2009 11:51 AM |
Is she purring? Is it open loop? where are you dumping? |
dancour
| 29 Mar 2009 04:13 PM |
Seems to be working fine. I do notice my water pump cycles more often as should be expected ...at least in stage one. I'm thinking of replacing my 25 year old submersible with a Grundfos variable speed deep well pump.
As what happens to the water after I take 10 degrees off it, I can either dump to a leaching field or my pond.
Thanks for the question. |
GuyB
| 30 Mar 2009 08:52 AM |
Could you describe the leaching field required for your setup?
My well is 120' deep and rated at 30+GPM (they never did get it to run dry). I think an open system would be the most cost effective solution for our house. having completed the install, doyou have any advice for someone considering an open system?
dancour
| 31 Mar 2009 07:09 AM |
Advice you ask...
My best advice is to read every entry on this forum as well as http://forum.geoexchange.org. You won’t be long picking out the experts.
They will insist that you do a house heat loss calculation first, get quotes from contractors that have experience and training, make sure that your ductwork is a match for low temp high volume air and get to know someone who has a geothermal furnace.
A water-to-air system has its own specific challenges including water quality, pumping rate on a continuous level - no guess work, regulations in your area for spent water (second well or leaching field), electricity rates ( a loop system only uses a fractional motor to circulate the water).
I’m new at this and will add my thoughts after using my new system for a year.
Thanks GreenBuildingTalk |
project_x
| 31 Mar 2009 02:15 PM |
Dancour, the picture of the plumbing shows, two valves for the outgoing water. I assume you are set for different flow rates for each stage (the plumbing is different than the WF IM1585.pdf installation manual).
What are the flow rates for each stage?
Rob |
joe.ami
| 03 Apr 2009 07:14 AM |
Looks like a great job. Glad you gave props to your installer "Jacks heat pumps", Dancour. It is clearly the work of a pro. One question, when is the tax credit qualifying desuperheater going to be hooked up? J |
dancour
| 04 Apr 2009 01:57 PM |
You asked about when the DSH is going to be hooked up.
I'm still puzzled about the best way to do it. I know that a preheat tank is on the list but as for size or locations for connections, I'm at a loss. WF says this way. Any sugesstions? |
Attachment: Desuperheater Preheat Tank 1b.jpg
Bergy
| 05 Apr 2009 08:50 AM |
Dancour,
That is the best way to pipe a desuperheater to your Geo. They don't mention to remove whatever backfow preventer is in the dip tube of the first tank.
Bergy
joe.ami
| 05 Apr 2009 09:20 AM |
We actually feed ours from the top down but either will work. J |
