Which water heater will most likely be more
useful in my future, not yet designed, low/no-CO2 geothermal space conditioning and water heating system -
electric tank (actively heating or passively storing/insulating), gas-fired
tank (actively heating or passively storing/insulating), electric tankless, or
gas-fired tankless? In the future I'll
have a system engineered to
generate as little CO2 as possible while still allowing a "normal"
lifestyle. This might be a solar
voltaic-powered geothermal unit incorporating a desuperheater and
backed up by… (which of the above would best fit here)? In the now, my gas water heater sprung an
irreparable leak. So, I need to buy a water heater NOW but want it
to be a component of the FUTURE system (so I don't have to re-buy then
something I could have bought now if I knew what I was doing).
I need to heat about
six months of the year, cool about four, and neither about two (yes I know I
could reduce CO2 by not cooling, but with pollen and spore allergies it's a
good idea to keep windows closed and run air through the air-handler's
filters). Comments on the following thoughts???
Maybe electric tankless would demand too much electricity from the solar voltaic
(assume I'm not grid-tied), so electric on-demand probably would not be useful
in the future system. If I bought it now I'd have to toss it then.
Not combusting
carbon-based fuels in the future system rules out gas-fired tankless - unless it would hardly ever fire because the DSH kept the water hot enough year around. But my understanding is that geothermal will not provide efficient hot water in the ten winter months here, such that the gas-fired tankless would have to do most of the work in those ten months. Is that correct?
An electric tank model could be used as
backup when the geo wasn't warming water during the winter or to get the water temp all the way up if the
desuperheater didn't heat the water fully in the summer, right? But by the time I'm able to install
geothermal, electric tank water heaters might have been improved, and between
now and then, a gas-fired tank water heater would produce less CO2 than an
electric tank unit powered by my current coal-derived electricity.
So I think that means the water heater that
produces the least CO2 in the short run but could also be useful in the long
run best with a geothermal unit is a gas-fired tank that in the future system would store the water from
the desuperheater until the future electric tank unit calls for it, adds a few
degrees to get it up to temp, then sends it to the shower.
'Tanks (get it?!),
Gordon
