no need for programmable thermostat?
Last Post 28 Jul 2009 10:41 PM by TechGromit. 5 Replies.
crashkahunaUser is Offline
23 Jul 2009 05:15 PM
Is it true with geo when heating in cold climate that having a programmable thermostat may be counter productive? We are used to turning the temp down at night. We were told that it would not save any to do that since in the morning the auxiliary heat would have to come on so much more.
Also what kind of thermostat or indicator would you recommend to know when the aux heat is on?
HHHUser is Offline
24 Jul 2009 12:05 AM
VisionPro IAQ 9000 Honeywell programmable thermostat with outside temperature; controls temperature, humidity, and fresh air. It has a spot where you can lock out the auxiliary heater if it is above an outside air temperature; 0 degrees - 65 degrees, 5 degree increments. We use them!
25 Jul 2009 08:29 AM
Posted By How on 07/24/2009 12:05 AM
....and it is fair to say that once you are below your balance point (temperature at which aux. may come on), you will then not save money by dialing back at night.
Good luck,
Joe
TechGromitUser is Offline
28 Jul 2009 12:11 PM
There been quite a bit or research on this topic in this forum. See this thread,
http://www.greenbuildingtalk.com/Forums/tabid/53/forumid/13/postid/50527/view/topic/Default.aspx
I beleive the basic conclusion is that turning your temperastat down at night does save you energy provided that the Aux/backup heat is disabled and it doesn't matter to you that the system will take longer to bring that temperature back up to a comfortable temperature.
Bill NeukranzUser is Offline
28 Jul 2009 05:59 PM
I was one of the participants in this experiment.
A key comment to add to the summary above is that the experiment was conducted where there was adequate heating capacity.  I.e., the system is not 'short' on heating capacity.
Posted By a0128958 on 07/28/2009 5:59 PM
I think it's important to remember most systems are not short all the time.  That during many of your heating days, the system is adequate to heat the entire house without the assistance of Aux heat.  You will only be utilizing the AUX heat on the coldest of nights to assist the unit with heating.  How many of the coldest nights would depend on how short your system is for the heating load.  I beleive for the bulk of the winter, AUX heat will not be required, so long as it's disabled, you will save $.  You could always re-enable it for the few weeks or months of the coldest part of the winter.
People Online People Online: Visitors Visitors: 197 Members Members: 0 Total Total: 197
