Yes, but it doesn't matter what he has in his system, just what was in the system that the manufacturer used to calibrate the pump curve, pressure drop chart, etc. which is probably water near room temperature. He's just changing units from psi to ft of head.
There will be a correction factor for different fluids at different temperatures but it will depend on viscosity more than density in most cases.
