Posted By gregj on 19 Mar 2010 09:45 PM
I'll guess but since I'm not a pro I'll guess 3 possibilities that come to mind:
1. Pond is silting in and silt is covering the coils.
or
2. Coils are floating in the pond.
or
3. Water is not flowing through one of the coils
That's just it Greg
Silt is as good as saturated soil which is about as good as water.
Coils presumably would've been noticed floating when OP made a hole in the ice.
An air blocked coil would not have shown up a year later unless leak occured and the pressure looked good.
It was actually a rhetorical question.
The only real answer that condems the loop field as is would be- colder weather. If OP lives around me it can't be that but perhaps there are places that have had a colder winter this year than last.
Or maybe the pond had a tributary that has lost volume or re routed. Of course if this were true pond level would often drop.
Sensible things to check would be GPM and refrigerant pressure. Another suspect in my mind is the pressure switch. In spite of the high standards of quality control at the "little hands international" plant where these 50 cent switches are made; failure is not uncommon.
Extra loops won't hurt. Extra antifreeze sounds like a good idea. Just can't say either is gonna solve the problem without more info.
j
