fhp ww072
Last Post 24 Mar 2010 10:27 PM by joe.ami. 14 Replies.
emjohnsoUser is Offline
12 Mar 2010 02:25 PM
Our mechanical engineer just recommended a fhp ww072 6 ton heat pump (water to water) for our radiant heating a single story 3000sqft new house. Wondering if anyone has any experience with this heat pump?
geotekUser is Offline
12 Mar 2010 05:53 PM
A proper installation done by an experienced installer is more important than a brand name.
Choose your installer carefully and ask about warranty details.
12 Mar 2010 07:37 PM
Did your mech E perform a load calculation in compliance with ACCA manuals J and S before making that recommendation?
Ask him or her why FHP over Water Furnace or Climate Master.
I second the statement that the quality of the design and installation trumps brand issues
13 Mar 2010 12:53 AM
Will ask the questions and get all the load calc's/heat loss stuff early next week. Wondering what are the differences between the various brands, Water Furnace/Climate Master, etc.....
13 Mar 2010 07:55 AM
Differences are minor.
Warranties can vary (your installer plays a part in the warranty).
Two stage compressor can improve efficiency since loads are a moving target (referring to seasons).
geomeUser is Offline
13 Mar 2010 08:45 AM
The manufacturers web sites have manuals posted on their units. You can take a look to see the differences in features and efficiency.
13 Mar 2010 11:55 AM
Nearly all the two stage high-end units use Copeland 2 stage Ultratech compressors and similar peripherals so brand-to-brand differences are generally minor
A heating-only radiant system with a reasonably decent sized buffer tank may benefit less or none at all from a 2 stage unit.
15 Mar 2010 10:08 AM
Agreed - but with GEO W to W one should take advantage of cooling use also.
15 Mar 2010 10:27 AM
Posted By geotek on 15 Mar 2010 10:08 AM
If cooling with hydronic fan coils, buffer tank is still employed and 2 stage unit may still not have big advantage.
j
15 Mar 2010 12:07 PM
Thanks for all the information. I will have a meeting hopefully this week to find out the details of the recommendation. I'm sure this is a heating only location, jackson,WY, I know he was looking at the largest single stage pumps and came up with the 6 ton fhp, then mentioned he found a 10 ton. These seem pretty large to me, and said the cost is only 6K and 11K, that seems low to me with all the mentions on this site being in 25K+ range for smaller systems. More later.
18 Mar 2010 07:35 PM
Meeting is next week, but I did find out he wants to use a 10 ton unit now and 30 gpm instead of the 6 ton at 14 gpm. Basic difference is I want to put the pex tubing in my garage so I can melt the snow off the cars in the winter but basically keep the temps around 40 in the garage. Well water temps are cold, some say 41-42 degrees, others say 47-48 degrees, how much does that matter. Either of these units seem large, with the 10 ton being way over the top to me. I'm putting in R40 walls and R60-70 roof insulation so the envelope should be good. They think there should be adequate heat. Will get the raw numbers next week. Just want a ballpark are these units large? and will they last? or require maintenance due to water quality issues.
18 Mar 2010 09:54 PM
Yes X 3.
22 Mar 2010 08:20 AM
Once you have a heat loss calc, we will be able to answer your questions about size.
Regarding price, there is a big difference between off the rack and installed pricing. There is also a big difference between the cost of open and closed loop installation cost (could be more than $10,000 on a 10 ton).
j
24 Mar 2010 10:47 AM
Heat Loss was calculated at 105,000BTu/hr and the 6 or 10 ton unit, with lots of supplemental heat in various rooms. We get days/weeks of minus 0 temps, so the effectiveness of geothermal in my opinion is limited. The payback period was at least 11 years, so we decided to go with a electric boiler and put more money in the envelope than the system heating it.
in my area 105kbtu would suggest ~6 tons. When you say pay back was at least 11 years that is assuming anything else you install owes you nothing. Everything else is a loser and geo ECLIPSES them in ~11 years.
Problem here is your designer doesn't seem to know geo either.
J
People Online People Online: Visitors Visitors: 793 Members Members: 0 Total Total: 793
