I have a geomax 2 4 ton closed. Geomax is a rebranded climate master.
My lookup table at the 40F loop temp only shows up to a pressure delta of 4.25 psi, which correlates to about 12 gpm. Your pressure drop is 6 psi (38-32) @ 40F.
Charting the pressure drop vs gpm and extending the curve yields 6 psi equivalent to about 14 or 15 gpm at 40F.
