Gary Rumbaugh
03 Jun 2014 08:41 AM |
Had the system installed 2010 close loop system the house main level 960 Sq. Ft. loft 341 Sq. Ft.
Basement totaly under ground 960 Sq. ft. just two of us, very conservative with lights which most are LED's the utitily company has us on lower cost because the house is considered all electric, utitily bills run around $250.00 to 290.00 year around, kWh used on average is 3500 to 4500 per month emergency heat does not appear to be coming on unless I try to jump the heat more the couple of degrees but the unit seam to run alot any Ideas, I've talk with other that have Geo system there bills seam to be around 80.00 to 100.00 per month. |
docjenser
03 Jun 2014 11:50 PM |
If the utility bills run $250-290 even in the shoulder season, when the system is not running, there are likely other electrical consumers. Try google power meter or something similar to track down the KWHs. |
joe.ami
04 Jun 2014 09:30 AM |
We can not blame the geo without seperating other electricity users as Doc said. There is an article by a woman online that says (paraphrased) "My bills are not much lower than my neighbors so geo must not be saving me much........Now I know that each house has different requirements and demands......." Your electric cost (price per kwh) is low. A properly designed 2 stage unit should run alot. So where is the electricity going? Where do you live? What was the manual J load for the house? Electric or gas hot water? Do you have a DSH (desuperheater) and if so did installer use a buffer tank? Are other owners with geo at $80 to $100/month quoting whole house electric use or just geo? How experienced was your installer?.......... Oh yes we have ideas, have you any information for us? |
SkyHeating
20 Jun 2014 05:04 PM |
Is there any issue with the home? We recently had a customer that had $100 a month summer bills but $400 a month winter bills and they blamed the geo, when it was all said and done this new home had more leakage than a typical 1950's home and yes the geo was using energy but it was because of other issues, once everything was sealed and insulated better the bills dropped. However in your case as others have pointed out, your issue seems to NOT be your geo, or the bills would be signifigantly higher in the summer and/or winter than staying constant year round. Do you have a well pump that is maybe running all the time, an old fridge or multiple freezers in the garage or something else that would cause the issue. One way to know if its the geo or not would take you about an hour or two to get good data but might be worth it to keep your mind at ease. On a very cold or very hot day, check the amp draw/how many watts the system uses over the course of 1 or 2 hours, now figure out if everyday was like that day, how many KWh's you would use and then deduct that from your electric bill and now you know what your geo is costing in an extreme month. |
Visit my Youtube channel for product reviews and customer testimonials http://www.youtube.com/user/skyheating1 http://www.welserver.com/WEL0626/
