Posted By joe.ami on 25 Aug 2014 10:22 AM
"And your existing boreholes are 160ft/ton. So pretty much perfect (as far as these guesstimates go)."
There it is. Answer to the original concern.
The original question was about grout, but the concern was to make sure the installer did his job and whether or not to recommend them.
As I mentioned early on, it doesn't matter what you use, it simply matters that it is sized correctly. Fancy (expensive) grouts or loops may have applications, but in the context of residential geo, most times they will simply cost more with no return on your additional investment.
Where is a " like " button when you really need it?
Eric
