A yellow light indicates a Condensate Overflow fault. If flashing, the unit will re-try to start. If solid, the unit is locked out. Are you sure it's a yellow light and not an orange light? The blinking green light on the lower right is the status light, just above that is the yellow condensate light. Above that is a red light, then an orange light and then a green light. Did you cycle the power off and on after cleaning the pan? If you Google "SCM-183-16" you will find the Flow Plus Mini-Tabs. Order a container of them for your drain pan. They will help keep the gunk from growing in the pan and trap. Bergy |
