Geothermal Heat Pumps
thermal water mass storage barrels
Last Post 15 Aug 2014 10:32 AM by
Brian Wells
. 5 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
Brian Wells
13 Aug 2014 03:06 PM
Has anyone buried 55 gallon plastic barrels 2 feet below frost line and and looped them together to be their horizontal ground loop to have like a mass storage heat transfer system? Im in Connecticut and considering if someone has done this they are cheap and last forever and its 55 gallons absorbing ground temperature. thinking maybe 60 barrels for a 2.5 ton geothermal heat pump????? any suggestions? It would mean each barrel would have to displace about 145 watts of energy??
13 Aug 2014 03:38 PM
If you want a heat exchanger, best to stick with typical geothermal loops. If you want thermal storage, use a single tank (plastic or concrete), preferably in conditioned space. And expect ~1 day of storage from it (depends on size and temperatures).
joe.ami
14 Aug 2014 09:19 AM
Hi Brian,
I think you might tear up less of your lawn with a more typical loop system. If you want a hand in system design, start with heat loss/gain and we'll go from there.
Brian Wells
14 Aug 2014 12:52 PM
Its a 2.5 ton unit i have my own backhoe and a wooded area near my house so not a real issue digging up area I have put in loops before not a problem just wanted to find a use for these free barrels and thought I could incorporate it as a massive thermal pile.
joe.ami
15 Aug 2014 09:13 AM
"It's a 2.5 ton unit"......so we are designing the system based on a unit you already have? Do you know what the load is for the home?
Brian Wells
yes heat loss already was done and we have some additional gas heating units for cold winter nights.
Membership:
Kodyeutsler
People Online:
