Posted By joe.ami on 18 Aug 2014 10:29 AM
... WF and many other manufacturers ... claim you can install a DSH without a buffer tank. While you certainly can, those who monitor their equipment learn very quickly that it is not just far from optimal, in fact the heat energy could be extracted from the water heater instead of added to it. I learned this when a clients hot water bill (independently metered) went up with the addition of a dsh. ... Disconnecting your DSH will likely improve system performance.
I'm one of those who monitor my equipment (see
http://www.welserver.com/WEL0043/ ).
I'm also one of those who has a DSH connected without a buffer tank.
And I'm one of those who has shown that indeed heat energy gets extracted from the water heater and put in to the refrigerant line.
I've had my DSH turned off for 5 years now. No point in turning it on without a buffer tank, and, figuring out how to do this without putting it in the attic is difficult for me.
Unless you're one of the few minority where a non-buffer-tank DSH actually works, you'd be more efficient leaving the DSH turned off.
In my WF unit, to ensure the DSH pump isn't run dry, I removed the pump's in line fuse, labeled what it's for, and placed it in the bottom of the tray.
