I recently had a closed loop system installed for my house. Since then, I've had water pooling in my basement occasionally. (I thought it was originally due to air conditioner condensate draining problems, but hadn't actually had a chance to see the water accumulating.) I discovered the water is coming in through where the loop pipes enter my basement (at a relatively high rate). Two pictures are attached.
The water seems to be entering through the PVC pipe through which the HDPE-loop-pipe runs.
I'm interested in any helpful or general thoughts anyone has.
I also have some specific questions.
What's the proper way to fix this? Obviously, I could seal the PVC pipe from the inside. Is this a good solution, or should it really be sealed from the outside? (I want the best long term solution, not the one that's easiest to implement now.)
I had separate contractors for the outdoor work and the indoor work. (The outdoor people run the hdpe pipes into the basement and cut them off. The contractors are buddies and work together. The indoor guy just sets you up with the outdoor one, but they request signing separate contracts.) Is this something I would contact the outdoor contractor about? (It seems it was their job to seal the HDPE to the PVC.) Or is it possible that the indoor contractor did something they shouldn't have done and broke a properly installed seal? I'm trying to get an understanding of these things now so I'm prepared for the pushback that I may get if/when I contact the contractors to fix this.
Much appreciated.
