Keep it simple.
Rather than spending money for a WaterFurnace diagnostic aid, which may be expensive, where ownership may at minimum raise some eyebrows with the installer, distributor and/or WF, where it only works when plugged in, where you still have to manually write down numbers, where you could mistakenly or unintentionally change a setting, keep the monitoring separate and non-invasive.
The WEL accomplishes all this, and is probably (much) lower cost than the WF diagnostic aid. I can't imagine WF selling anything to an end customer direct, and I can't imagine a distributor or installer selling anything like a diagnostic aid at anything other than list price. (And I can't imagine one being available on Ebay.)
Get yourself a WEL, get some temp sensors, get a power transducer from Continental Controls along with some current sensors, hook the stuff up, plug the WEL into your router, and you'll be impressed and amazed at what you too can learn about how your system is performing.
And, assuming you have PT ports in your water lines, get yourself a pressure gage with an appropriate probe, and now you can use your WEL to compute water flow, EER and COP. And then check the specs to see if indeed your system is running well.
Knowledge is power.
While the WEL accommodates refrigerant pressure gages too, this is the one thing I don't recommend proceeding to do. Everything to this point is non-invasive and thus non-warranty affecting. Pressure sensors on the refrigerant ports is a different story. Regardless of what you read, they will eventually leak.
For an example of measuring everything possible with a WF system, take a look at what I've got set up for a residential structure, at:
http://www.welserver.com/WEL0043 .
