Mitsubishi, Panasonic, Trane, and maybe some others have commercial water source variable refrigerant flow (VRF) systems that are close to what you are describing I think. These could be applied to a house if one wanted to. I'm envisioning one or more indoor fan coils, or ducted air handling units with a refrigerant coil (for heating or cooling) connected to an indoor compressor unit that rejects heat or draws heat (in heating mode) from a source of water. This "source" of water could be made closed loop and controlled to elevate the temperature in the summer and with careful piping and control this water/fluid, could be piped into as many heat exchangers as you want, to heat (in the summer) domestic hot water, hot tub, pool, etc. These would be piped to ensure that heat is rejected to the various loads in decreasing order of temperature or hottest loads first, if all heat loads are satisfied, excess heat could be dumped via a final liquid to liquid heat exchanger with well water on the other side. In the winter the entire system could potentially reverse and source water could help keep something cool or cold like a fruit cellar or walk in cooler. However, I've never seen this done before and usually in the winter heating mode all the heat is extracted from a borefiled (closed loop) or well water (open loop). I think it would be hard to recoup your initial investment for single family homes as you need lots of hours with simultaneous heating and cooling loads, to produce savings to offset the cost of the system including the VRF units, and the water side components (pumps, valves, pipes, and multiple water-to-water heat exchangers). Also, in this style of equipment the smallest unit I am aware of is 6 tons nominal capacity, which is probably a bit over-sized for some(maybe most) houses.
