Posted By electrodacus on 20 Mar 2015 08:09 PM
Not sure what liquid are you using since is close to freezing maybe is not water.
20% methanol. Heat capacity 3%-ish lower than pure water.
1 US_gallon-°F/min = 485 BTU/hr = 142 watts.
8 GPM x 7°F x 485 = 27.2 kBTU/hr = 8 kW
1800 x 1.12 x 4 = 8kW
Congratulations, your calculator works, BUT your answer is wrong.
8 kW is just the heat extracted from the loop. You ignored/forgot
the electrical power used to run compressor, blower and circ pump.
That all shows up as "electrical resistance heat" inside the envelope.
Conservatively, my Waterfurnace ND038 (running in stage 2), will
have a COP of about 4.0 (for EWTs in the 40°F vicinity). However,
my system normally runs in stage 1, where COPs are even higher.
(Waterfurnace specifies COP 4.58 @ 40°F EWT, 8 GPM, stage 1.)
But sticking with stage 2 @ COP 4.0, 8 kW heat of extraction yields
10.7 kW total output, with only 2.7 kW purchased from the grid.
In order to find out the average COP you will need to monitor ... blah, blah,blah
Sorry, in order to do that I would have to
care. Best I can tell you is
that in February 2009 we used an average of 57.1 kWh/day
total.
That includes heat, hot water, lighting, cooking, laundry, TV, and
tormenting the cat. Thermostat pretty much glued to 70°F (24/7),
2200 sqft living space over 2000-ish garages/basement/utility room.
1950's stone & concrete block construction. Decent insulation for its
age after major renovation in 2001 (but no upgrade to the old HVAC).
I was expecting someone has done a more scientific test related to cost amortization
Folks with a basic grasp of the difference between "huge" and "tiny"
routinely make "scientifically" valid estimates and decisions without
the bother of calculating everything to 0.01% (pseudo)accuracy.
With winter coming on, our 30-year-old oil furnace was nearing death,
(and our ancient central AC had recently expired). This was summer
of 2008, with fuel oil moving toward $5/US-gallon, and the (second!)
GWB market-meltdown just getting underway. My choice was to spend
big bucks to continue burning $5/gal oil (and to replace the air/air AC),
or go with geothermal. No natural gas available. Location not suitable
for solar -- steep, shady valley surrounded by tall oaks & poplars --
not to mention the much higher PV prices back in 2008 & 2009.
Hmm, ponder, ponder... combustion-free 4+ COP (w 30% tax credit),
OR yet another stinky $5/gal oil furnace plus noisy outdoor AC unit,
OR incentive-free resistance heating with electricity from the grid?
...you need more "analysis?"
Really?? Gimme a freakin' break!
Looby
