I have a Climatemaster Tranquility 27 Digital TEV038 3 ton geothermal heat pump. Does it support "Compressor Reverse Staging"?
I have an Ecobee3 Thermostat. One of its settings includes: Compressor Reverse Staging
-- If enabled, the thermostat will cycle down from the higher stages so that as it approaches set point it will only be running in stage 1. The thermostat calculates which stage to start the HVAC equipment in depending on the indoor and set point temperature delta. . As the stage 1 temperature delta is exceeded, the second stage will engage. Once the equipment has brought the current temperature back to within the heat or cool differential setting, stage 2 will disengage and stage 1 will remain running until the set point is reached.
I would like to use this feature if the equipment supports it? |
