This is a very interesting paper to read for those of you interested in how the construction of a borehole field affects GSHP performance.
Key introductory points:
Bore hole fields are planned for decades.
Energy extraction or injection, even only for seasonal use, may introduce a growing thermal anomaly in the ground.
The thermal reach of individual boreholes may interfere with each other.
In practical applications, 5 m separation distance is recommended for avoiding substantial interference between boreholes.
While thermal interaction amongst two nearby boreholes may be acceptable, interference will be more significant in arrays of multiple boreholes. To the point that some don't perform hardly at all and thus don't need to be drilled (and improve the project's economics).
See:
http://www.linkedin.com/red...cking_anetHope you find this interesting / fascinating!
