Without going to the effort to look up data, I'm going to venture a comment that it probably has to do with specific heat, i.e., how many Btus of heat it takes to raise the temp of 1 lb of material 1°F. The plastic may be better in that regard than aluminum or copper. You want to be able to suck a lot of heat out of the warmer air without having to raise the temp of the medium very much. For instance, on a volume basis water holds a lot more heat than does rock.
