Furnace Humidifier Recommendation
Last Post 15 Mar 2008 06:54 PM by warmsmeallup. 5 Replies.
KrispsUser is Offline
18 Feb 2008 10:37 PM
I installed a humidifier on my forced air furnace a few weeks back and just want to pass on my praise for the product.
In the past, I've used one of those humidifiers you can buy at Walmart which just heat and vaporize the water.  These products draw a lot of current and my hard water really scaled the heater pad and filters, required constant cleaning and filter replacement.  Also, it's inconvient to continually fill the tank with water, and it doesn't do very well to humidify the whole house.
The furnace humidifier I bought is a Desert Springs model, and I'm really impressed with it.  It is installed in a bypass around the furnace blower.  Inside the humdiifer is a water bath which is controlled by a float level valve and a series of plastic discs.  These discs rotate through the water bath and the furnace air blows across the top of the wetted discs.  It's very simple but very clever because it uses almost no electricity (just a little 24VAC motor to spin the discs), hard water is not a problem, and there are no filters to clean or replace.  You can get an optional flush kit that will automatically drain the bath periodically but I do it manually, this helps to remove the mineral deposits which form in the bath.  As well as a clever and simple design, it seems very well constructed.  It is durable and solid, not like typical cheap and delicate plastic crap that's become common in many products.
But best of all, with the higher humidity in the house, I'm more comfortable at a lower temperature and I no longer have lizard skin.
glenfotreUser is Offline
04 Mar 2008 12:58 PM
Does this humidifier have its own blower?  If not, and it is installed in a bypass around the furnace blower, how does it get air flow through it?  We run a console model humidifier in our home to bring the 15% humidity up to a more comfortable 35 - 40% which works fine, but I was planning to install a Venmar air exchanger in our new home and thought of installing the humifier in the incoming side of it rather than the furnace ducting as the Venmar will run much more of the time than will the furnace.
richfosterUser is Offline
15 Mar 2008 01:18 PM
The supply and return air plenums have openings cut in them so air can pass through. As it is passing through it picks up moisture. the blowing is accomplished using the blower for furnace. The 24volt step down trans former is powered when the blower comes on therby enabling the humidifier to emit humidification (if the humidistat is calling). central humidifiers are not without thier peticular challenges. high maintenance, introduction of high humidity into inside of furnace. but they work very well ..enjoy
15 Mar 2008 03:03 PM
richfoster is right. I have had the humidifier installed over most of this winter. The only maintenance so far is a manual drain maybe every 2-3 weeks. I don't think my water hardness is really a problem (I mainly just have some iron), the draining is not really all that necessary for me. It requires much less maintenance than a heater/vaporizer type humidifier. I don't expect there is a problem with introducing humidity into the furnace because the airstream only aborbs as much moisture as is possible (unlike a vaporizer or atomization nozzle), so there can be no condensation inside, and it's controlled by a humidistat as well. It introduces a nice slow and steady increase in humidity, it took about a week to bring the humidity from 20% to 40%. I did find it's best to maintain about a 35% level, otherwise some of the bad windows get condensation when it's very cold outside. Below is a link for more info about the humdifier.
http://www.mediawaveonline.com/humidifier/desert-spring-humidifier-buy.php
15 Mar 2008 03:20 PM
I spoke with the manufacturer and he recommended against attempting to connect the Desert Spring to the Venmar as he said that it needed warmer air coming in so that it would absorb more moisture. I suppose that if one were to install it on the furnace and connect the humidistat so that the furnace blower (only) would come on when the humidistat called for moisture, that could accomplish the same result. Our air in AZ is so dry that we need to increase the humidity 24/7/365.
warmsmeallupUser is Offline
I installed one in my furnace as well, though it's not a Desert Spring". It is connected into the return side of the furnace and it's connected to special contact points inside the furnace that only turn it on when the system is calling for heat, not just when the fan is on. That way, only warm air passes through it.
Comfort Radiant Heating, LLC
www.comfortradiant.com
Membership Membership: Latest New User Latest: ecoSmart Solar Powered Building/Remodeling New Today New Today: 4 New Yesterday New Yesterday: 10 User Count Overall: 17379
People Online People Online: Visitors Visitors: 486 Members Members: 64 Total Total: 550
