ICFcontractor,
Thanks. I'm with you on the positive wall floor connection. The qty of heat flow is based on Delta T , surface area and length of path. So in my case, the radaint heated floor has an area 4" wide by the perimter wall length. Deta T will be; Floor temp-wall temp. Maybe 85F-65F? The path length is quite long, 12+ feet down to the footer. The heat path length is critical because a gradient forms. Ground temp is 55F and wall Temp could be 65F. That is a small Delta T over a long gradient.
The deck and roof are bigest concerns. I will be proposing to the joist manufacture that the deck slab ends at the foam and not cover the wall. The only exposure to the concrete wall would be the joists themselves. And the joist ends could be covered with a thin layer of "foam in a can". In this method, the main homes structure is maintained. The deck is one level. I would like to construct/ poured the roof using the AAC as a top cource on the ICF.
Patrick T
