I just remodeled my house this summer, we added two shed dormers to a cape in Maine and the Insulation contractor did not want me to use soffit vents (foam channels between the rafters venting from the soffit to the ridge vent). They're recommendation was to not use any venting. This did not sit well with me. Also when I contacted GAF/ELK (shingle manf.) they recommended using soffit vents for extending shingle life. I built with 2/10 rafters and used dense pack cellulose with soffit vents. After much research and discussion I went against the recommendation of the Insulation contractor. Now that it is winter I can see the direct result of my decision and I'm glad I went with my gut.
My ridge vent cover 75% of the ridge on my roof, the ends are not vented. The sections that are not vented melt the snow much faster, thus much more heat loss. These areas have a much higher risk of ice dams as well as a result of not being vented. Looking back I wish the whole ridge was vented but not much I can do now. I'm pleased with my decision and would personally recommend using soffit vents. Not venting a roof structure is relatively new and I believe untested (10 years of results is minimal when you want you house to last 100+ years). Venting has worked well for many years and I belive even with new insulation options still makes sense.
