Which would cost less?
I want to build a three story home on a slab. I would like the floors the be steel decking with about 1.5” of concrete over steel joists.
Would it be cheaper to build using steel sips OR a steel frame with magnesiacore on the exterior, open cell spray insulation and then sheetrock on the interior walls?
Either way the exterior would be stuccoed using something like stuccoflex
Thank you,
Shawn
