General Forum - Residential
xps vs eps
Last Post 23 Feb 2009 11:27 AM by
BadgerBoilerMN
. 1 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
thagreen
11 Feb 2009 12:11 PM
Hi all ,
Just came across some interesting data about xps and eps.
XPS is great for density but not sure i'd use it myself for underlayment regarding concrete floors after reading this ! Check out the link.
www.
foam
control
.com/downloads/brochure/
Foam
Control
EPS
-Water-
Absorporation-Facts.pdf
BadgerBoilerMN
Here in MN a vapor barrier (below the XPS) is required. You must also consider XPS below radiant floors drier by virtue of the radiant heat applied. In New Mexico, AZ and S. Texas not really an issue. As the article points out XPS is clearly hygroscopic.
When in doubt use Crete Heat.
See Don on this...
hehehee
Membership:
croccohvacusa
People Online:
