This is the residential forum and these systems are designed for commercial applications. I have yet to see a highly efficient residential system and never seen one with the counter flow. Maybe I can just get the core and make a box to put it in, add some fans,controls,dampers, and then you have a standard HRV or ERV. Until the last few years good residential models weren't even available and then the ones on the market today are not near to 90% efficient. The best one I have found is the Fantech ERV or HRV, not because of the efficiency rating, it isn't that efficient.
http://www.fantech.net/hrv_erv.htm
http://www.fantech.net/controls1.pdf
What does make the system efficient is the user friendly controls, 3 fan speeds, overrides, dehumidifaction override, timer that allows for setting of 15on/45off, 20on/40off, 30on/30off, You can add up to 3 boost switches, exterior dehumidistat, and some units actually have a recirculating mode that allows you to take air in from one location within the house and circulate it throughout. What I have found, is that by making it user friendly the homeowner has greater control over the indoor air quality. We have even gone back in after on HVAC guy installed a different HRV unit that didn't even have a timer switch and replaced this 2 year old unit with one of these. HRV or ERV is the question and this is reliant on where you live. Here in the cold Northeastern US I use an HRV, but if I were in a more humid climate the ERV would be the choice. What I have found is that using an ERV as suggested by other professionals is not the right choice when you have a very tight house, especially if it's an ICF house. The ERV units don't allow you to expel the moisture from within the building and in one case neccesitated the use of a dehumidiifier to control the moisture levels, not great for an energy efficient house. Even through HRV units are not designed to control humidity they can and do work for this purpose. If the exterior air is dryer than the indoor air then the unit will bring dry air into the building and expel the moisture. But if it is extremely humid then the opposite is true and the unit brings moisture into the building. Here is the thing, when it is extremely humid in this region we don't ussually have need of this unit running. Like currently, the wheather has been extremely lousy here in NE with more rain in June than I have ever seen and temps way below normal. So even here in late june with daytime highs in the 60-70's we typically have the windows open and the unit is shut off. I tell my customers to only run the unit, when all of the windows are shut. If you have a window or two open shut the unit off entirely and let mother nature do it's thing.
Tom Pittsley
[email protected] www.eebt.org
