Greetings. First post, so if I violate protocol, please let me know. The new homes company I work for is interested in "going green" but we first need to learn to walk before we can run. We'd like to start at the bronze level. I have built about 18 Energy Star homes so the first "building block" is in place and I have been to some green building courses as has my boss, so we are not totally green on Green - sorry couldn't resist. Anyway, I'd like to make a list of "high value" upgrades that we can use as basics for our green building. OK - very cost effective upgrades to earn us green building points. The ones with the most bang for the buck, both performance and points wise. We intend to build under the NAHB-Green program, however high value upgrades probably earn points in most programs. Our location is Raleigh NC (zone 4), so that may have some bearing on your replies. Things like geo-thermal, PV, SIP and spray foam are not in the equasion as these are cost prohibitive for our situation. I guess you would classify this as light green building. Granted the various components need to work toghther. So at this point I guess I'm just creating a menu of the high value items.
Thanks in advance.
So, here is part of the list I've complied so far:
Points earned by manageing site work by a trained person.
Building on infill lots
Building on lots with ready access to mass transit
Orienting house within 20 degrees of south and designing glazed areas to take advantage of pasive solar heat gain.
Building homes below the predetermined sq ft size thresholds to gain resource effiency points.
Decideout trees shading the south side during the summer.
Radiant barrier roof sheathing (cheap upgrade compared to the payback).
Home buyer education book (once we make one, each additional one will just be another version or copy) Higher Seer heat pumps that earn rebates form our local power utility.
House design that allows all ducts and air handlers to be within the conditioned space.
Engineered framing components like roof and floor trusses (which we use anyway)
Advanced framing techniques to maximize R-values of wall assemblies
FSC lumber
Covered Entry doors (good basic design - I have never built a house that didn't have a covered front door)
18" wide overhangs at the eaves and 12" at the rakes.
Flashing details shown on plans.
1.5 GPM max faucets (most modern ones are anyway - aren't they)
Rain barrel to capture rain water for irrigation.
Low VOC Paint (Not that much more $ and readily available)
Recycled carpet padding (I guess rebond satisfies this)
Green certifed carpet
Energy star bath fans (only a few $ extra)
Exhaust fans verified by our energy rater (they do that anyway)
What can you add to the list?
