Fiberglass square posts and steel cable
Last Post 12 May 2012 05:05 PM by FBBP. 4 Replies.
Leon HuiUser is Offline
10 May 2012 07:15 PM
Is it possible to use fiberglass square posts, drill some holes to thread stainless steel cable to make my own steel cable deck railings? I'm thinking of reusing some reclaimed fiberglass square tubes...
ICFHybridUser is Offline
11 May 2012 10:18 AM
I think it depends on how rigid the posts and the sidewalls, in particular, are. Metal cables need to be able to develop a certain amount of tension to maintain appearance. If your end posts are adequately fixed, you may be able to have the cables pass through the posts with some success, but then the mid-span posts contribute little to the assembly.
11 May 2012 10:46 AM
Posted By Leon Hui on 10 May 2012 07:15 PM
Check with your local code official before spending any money.
11 May 2012 11:20 PM
I bet that the corner/end fiberglass posts would be a whole lot stronger if you poured them full of concrete.
FBBPUser is Offline
As Alton said, check your codes. Many A.H.J. won't allow any railings that allow kids to climb over them, and rightly so! Cables provide the perfect ladder!
