I'm interested in fresh air intakes and/or heat exchange ventilation that is passive and either adjustable or programmable.
The house I'm building will be different from the building I live in but pretty similar in a lot of ways. I have lived in this building since I built it in '01. I know that this building works OK and I want to improve on it for my future house.
The current building leaks air. It's supposed to hold various petrol vehicles so leaky is OK. I heat with wood and leaky works pretty well for that too; I burn a bit over 2 cord a year at a cost of about $4 for fuel for the chainsaw, so the leaks aren't that expensive either.
For the house I want NOT TIGHT but tighter. More control. Reducing conductive and radiant heat losses are imporant to me. Keeping air exchanges is also important.
The big squirrel-cage blowers on manufactured heat exchangers are WAY too big for the 1,000sf house I'm building. I CAN easily run 2 or 3 small fans all the time. I currently run a brushless fan that ventilates 3 areas of this building, including hydrogen from the battery box. (I'm off-grid with a very small electrical system.)
I am interested in something like this convective counter-flow heat exchanger:
http://sustainabilityworkshop.autod...ion-system . These have been in use in GB for a few-to-several years. Everything I read about them seems to be written by people who really want to believe they work. While I also believe that convections work, I'm not certain it'll work in all situations. Would a wood stove draw cold air down what's supposed to be the hot-air exit?
When I say "adjustable or programmable", I mean either a manual knob or an electronic control. I built the analog differential thermostat that runs the pump on my solar hot water system and may replace the analog unit with an Arduino computer for fun and to account for more factors.
Passive heat exchangers?
Low-power heat exchangers?
Seasonally adjustable air intakes? (I just scuttled my 100' earth-tempered air intake but this first post is already too long.)
Thanks.
