climate zone 7 winnipeg.
wall from the outside in:
acrylic stucco, 5/8" of portland stucco, typar, 2 layers of 15lb felt, 1.5" fiberglass faced polyiso, typar. 1/2" plywood, 2x6, r22 roxul, membrane, 1/2" drywall.
wondering what type of paint I should use to premote more drying to the inside of the house. will normal laytex be fine? or should I be looking at other options
also in shower areas that will receive a water proofing membrane like KERDI should I include membrane behind the drywall? kerdi acts as a vapour barrier in its self. or will leaving the membrane behind the wall be fine.
thanks |
