It varies a lot by location and project, but the average 5-8kw system in MA is running ~$3.50/watt, down from $3.75-4/watt in Q2 2014. That's the whole soup-to-nuts turnkey installation, before subsidy. Some bids are coming in well below the average, and higher efficiency panels (20%+ instead of ~15%) carry a 35-50cent/watt premium. YMMV- no telling what it is in your neighborhood. But even if it's $5/watt today, it won't be anywhere near that in 2020.
These people seem to think it's about $4.40/watt in VT, but that's probably SOOooo 2014.
SolarCity (the largest residential PV installer in the US) just open and office in NH, not sure which of the bigger solar outfits are targeting VT's smaller market. But the utility & state in VT are more solar-friendly than NH, or even MA, which is bumping up against previously set ridiculously low 4% of peak load net-metering limits in some parts of the state. In VT net-metering won't be revisited until PV output is at 10% of the all-time grid peaks, and even that may be expanded before it becomes critical.
In Oahu's heavily built-out(and still booming) solar environment some substation feeders have been backfeeding PV that is running at ~150% of minimum midday load. The utility had claimed the backfeeding PV was a source of grid instability and had been denying new solar going in on those feeders. Enphase ( of the inverter vendors) has long term minute-by-minute data logging on their systems had a huge database to mine that disproved that thesis, and even went so far as to claim that rather than being a source of instability, distributed PV was in fact stabilizing the grid, and could be even more stabilizing if a software change was made to allow longer ride-through of perturbations, previously limited in duration by regulation. A complete independent analysis & review of that huge dataset and subsequent testing of the revised ride-through upgrade by engineers at the National Renewable Energy Lab agreed, and they are now required to allow new solar until the mid-day peak output is at 250% of minimum daily load on any given feeder, at which point there will be even more data. Enphase was also allowed/encouraged to remotely download the software upgrade to their installed inverter base in all of Hawaii.
That is a much higher level of PV power than VT's net metering limit of 10% of peak, and in VT's PV friendly regulatory environment that limit will almost surely be lifted- the 10% was conservative to ensure that it could be managed without new grid control assets, but at the time that went into effect no one knew just how conservative it was.
In MA last fall there was legislation being fielded that would have lifted net-metering limits completely, with the implementation of a minimum-billing scheme for months when the PV was net-zero at the meter. They ran out of time on the legislative session before it could be voted on, and there are now competing variations on the theme being passed around. But while the state reps have been having their chat party, there are locations in MA that are more than 99% of the way to the 4% cap (which some of the utilities want to keep, protecting their shareholder interests ahead of the ratepayers interests.)
