I'm sure many better minds than mine have worked on this question; has anyone come up with an effective buildable wall for cedar shingle siding, that doesn't involve two layers of sheathing? It seems that I need one layer for structural integrity in my coastal wind zone (02807), and a second layer outside my exterior rigid insulation, for a nailing base. It also seems as though the inner layer should be the air barrier (Zip system?), given the thousands of shingle nails. So, unless someone has a better idea, proposed stack up would be shingles, CDX, 2" xps, taped Zip, 2x6 frame w/ cellulose, blueboard/plaster, paint. Questions: Is there a way not to use two layers of sheathing? Do I need a WRB behind the shingles, and if so, what? Would taped polyiso make an air barrier instead of Zip, or do the shingle nails preclude that? |
