Solar and Wind Power
How does one power an amplifier with solar panels?
Last Post 05 Jun 2009 07:34 AM by
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
sunspot
11 Jun 2007 04:30 PM
I have a question for a knowledgeable person regarding how to supply solar power to an amplifier. How many solar panels, batteries, and other devices would be needed to run an anmplifier that is 150watts, 120V-60hz which has a plug (in other words would I still be able to plug in the ampllifier)?
mmelvis
08 Sep 2007 07:11 PM
Have you tested the amp to see what the current draw is going to be ? This will be a large factor in the configuration of batteries and solar panels. Will the amp only be used during the day or will there be night use to ? What type of amp is being used, tube, solid state ? What is your budget or ball park?
If you have a large area and some wind you be able to also use a small wind generator ?
octoberdan
26 Apr 2009 03:37 PM
There's a relevant DIY guide here: http://www.instructables.com/id/Solar-Powered-Amplifier/
Buy a device called "Kill-A-Watt" and measure the power draw with typical music. Then buy solar panels and an inverter rated at about twice the power the amp uses.
Membership:
croccohvacusa
People Online:
